Is it possible to run a sway bar with basic front bag system?
slonlow2000
May 13, 2015
154
7
I picked up this truck at the end of last year.
Been poking around fixing what I can, and keep coming back to the sway bar. Its running drop spindles and cups in the front. The bolts for the original sway bar hold down are still in the frame rails. I'd like to get a sway bar back in there, just wondering if its possible with this setup without a lot of modifications. Is there a factory type sway bar end that will allow an OEM sway bar to work?
This is what I'm working with now.
Thanks in advance for any info
Yeah I found that the day I took these pics. Its been in my garage since. I'm about to finish the walls in the garage then its going up on jackstands.
Main reason is handling. My last 2 trucks were RCSB's lowered only to handle like sports cars. I want this to have that feeling. I never use the side to side function. Only time I used the individual valve is to level out if need be.
