Geometry issue
bgray
Stylish Canadian
Mar 17, 2012
3,052
96
Onterrible, Canada
Hoping someone here has some incite
My new ram has a 4 link and panhard bar from
Factory. I added new link bars that you can adjust, and rear air bags to replace coils
Naturally as its lowered the axle has shifted to the passenger side. Hence why I also purchased an adjustable panhard bar. But when I go to adjust the rear axle over it starts to lower the driver side and raise the passenger side. Even if I completely air out the rear bags it still sits lower on the driver side.
Any incite to what's causing this?
Main question, Individual bag control or bags tee'd together?
Other Comments
are all the lowers adjusted to the same length and the uppers adjusted to the same length? if they are different lengths, it can cause the axle to rotate unevenly causing the twist in the axle.
The panhard bar mounting point on the frame will also cause a pivot effect. it is not pushing directly to the center of the frame cross section to center your axle. it pushing on that pivot point which is located XX" off the center.
the frame is going to pivot at it's CG. so if you're applying the force in a plane that is not on the x or y origin planes from the CG, you will get lean from one side to the other.
I'd pull the panhard and see what happens
this is fine, as long as you DO NOT DRIVE IT, just cycle the suspension.
