Fixing some holes
D1nman
Mar 27, 2012
2,326
5
West Monroe, LA
Ive got some small holes drilled in my console side pieces, about as big as a 3.5mm headphone jack. I want to cover them up, i know to sand them down but how do i fill them? i was then planning on dying the pieces
and i would put a piece of tape on the outside and aplly from the inside, so that you have minimal sanding if any at all.
Don't you mean tape the inside and apply from the outside?
I would glue some pieces of plastic to the inside and run a thin coat of filler over the hole. Tape will stay flexible and the filler could crack in time.
You could probably even use a sandable 2 part epoxy thats not body filler.
Thanks guys
i've got some plastic welders laying in my room if that'd work. Here are the holes. still wondering what the fuck they were for
Maybe so. Came out of a sunk 2500HD crew. Not sure what the ones on driver side were for, that close to the floor and seat and all
