DRL/ signal LED flashing problems,
marc
WhiteSilvy
May 16, 2013
5,303
123
31
canada
ok so i thought i had fixed the problem i had but i seem to come back every now and then and now it does it all the time.
when i signal left the right LED flash slightly and left ones flash like normally
when i signal right the left LED's flash slightly and the right ones flash normally
here is a video of how i wired the DRL's and showing what is happening with the lights.
do i need resistors somewhere ?
please help
So, you don't have resistors anywhere in there?
I'd bet that's your issue.
Do you have the flasher mod done or a new flasher for leds?
do you have normal or LED bulbs in the tail lights. i found even with resistors and the flasher mod, if i have LED tail light bulbs, and my switchbacks, it does this, and when i hit the brake pedal, the blinkers in the mirrors would slightly light up.
i put standard bulbs in the taillights and it was good again.
Same. I ended up with halogen tails and turns again too.
Bryan, did you have resistors out back too? or just up front like me? I don't remember
i just have the flasher mod done, no resistors anywhere.
i just dont understand that the opposite lights are getting power.
the good thing is it doesn't happen when i have my drl's in the on position since the one just stay's lit and the other one flashes.
can i get that in english and not french conadian?
and can you answer my questions.
do you have LED tailight bulbs? or just DRL/blinker? DRL shouldnt effect anything unless you got rid of the DRL and turned it into another parking/blinker.
if you look at the wiring i got rid of the DRL and made both the bumper light do the same thing. like signal and then drl's.
and yeah i do have LED brake and signal bulbs... maybe ill change those out tonight and see if that fixes it.
I had this problem about a month ago and fixed it with the led flasher on my 04 sierra.
