Discussion: How to Replace 99-02 Headlamp switch with 03-07
uphigh2wd
Lifted 2wd club
Mar 25, 2012
Clovis, CA
How To: Replace 99-02 foglight switch with 03-07
This is a quick how to thread on adapting the 03-07 updated cargo and foglight switch to your 99-02.
The main and ONLY function this serves is an updated look....i like the darker color as well as the darker buttons compared to the factory gray. And I personally did not like the whole 'CARGO LIGHT' displayed, and simply wanted the symbol to display instead. Wont matter to most people but to me...i like the little things!
This is very simple to do. No internal modifications required. You simply need to cut and splice both the factory harness and new connector. If you have access to factory crimp on pins it would make it look like factory and you would simply crimp the wire and plug it into the connector...unfortunately i did not have access so the solder/heatshrink method was best for me.
Here are the connections you need to make:
Factory / Update
Purple - Purple/White
Orange - Orange
Black - Black/white AND green/white
Grey - Brown/white
Blue/white - Blue/white
On the factory 99-02 harness ill explain what each color functions as:
Purple - LED indicator when your fog lights are on. (+)
Orange - Positive (+) trigger to signal your fog lights on
Black - Ground
Grey - Parking light illumination
Blue/white - Cargo light power
03-07 foglight switch:
Purple/white - LED indicator when your fog lights are on (+)
Orange - trigger to signal fog lights to turn on
Green/white - ground for the LED indicator
Black/white - Ground
Brown/white - Parking light illumination
And the following are the pics:
And there you have it. Like i said, very simple to do and its the little things that count!
!!Correction!! So i just found out that the 03-05 foglight/cargo switch you can physically swap the faces and the buttons on. They use the exact same buttons, exact same face, and the housings are almost identical.
Part number of the switch you will need to swap the buttons/face with is 15076588. The one i used is from an 06 and i will post up the part number on that one next time i pull the dash off.
Again this mod theoretically does not gain you anything featurewise...all it does is give you the dark buttons compared to the lighter gray the 99-02's had....and the faceplate has the symbol for the cargo light instead of saying 'cargo light'. I personally think it looks cleaner and a little more modern. As you can see the finger guides are in the exact same placement as well as the notching on the inside of the faceplate where the circuit board would rest against.
Anyways onto the pics:
Although i only have the cargo switch with no fog button, the upper part of the circuit board is almost identical, i used a ground contact button, unlike the newer switches which has offset 'fingers' that slide and contact the ground circuit. But heres the circuit boards and my cargo light fitting into the updated face no problem.
Hello all, the following how to is a project of mine i have been thinking about doing for a year or so now, and just spent the last couple months planning it out. Before i get started i want to let everyone know that i make my how to threads very detailed, and plan to continue to add tech to this forum and should anyone have any questions on anything electrical, send me a PM and ill do my best to answer. Also i wanted to prove to anybody questioning any project with a 'can it be done' thought, that yes with enough planning, trial and error, and effort, anything can be done.
So a little background on this project, i have been wanting to do this updated look for a few reasons:
1) Every 99-02 owner knows that in order to turn your headlamps off in AUTO mode you have to press the dome override button 4 times. With the 03-07, you can turn the switch backwards to override the headlamps. This is programmed into the BCM.
2) The 99-02's have a lighter gray colored switch panel to them, whereas the 03-07 have a darker graphite shade, as well as the knobs on both switches relate in color to the corresponding controls as well. I like the updated look.
3) I like challenges.
I have also adapted the updated cargo/foglight switch which was super simple to do, and its one of those little things that cleans up the appearance as well. That can be found in another thread: http://customgm.com/f14/how-replace-99-02-foglight-switch-03-07-a-1004.html
Now onto the technical part of this whole thing. The 99-02 trucks run off of a positive trigger. Meaning almost everything in the vehicle has ground applied the whole time, until you give it 12v power. 03-07 trucks have negative trigger, which is opposite...almost everything is powered, but needs to be grounded (have a negative trigger given) to them to complete the circuit. That right there is a big problem in the way both switches work. To make the updated switch work in a 99-02 platform you need to modify a few parts internally. This may be a little overwhelming to some people but with decent soldering skills you can pull it off flawlessly.
Schematic's you will need:
First things first, this is how the inside of a circuit panel looks like for the 03-07 headlamp switch.
Ground is the main circuit tracer in the middle, as you can see with every revolution or contact within the panel, ground will be applied to another tracer to trigger the attached wire.
We will now need to modify this switch to work as a positive trigger. Note: this switch is set up as a negative trigger so everything that NEEDS a ground trigger to work needs to be removed from the circuit path.
You need to drill 2 holes with an 1/8" bit or a bit big enough to sever the tracer from making contact. Ive provided a couple of photos to show where to drill. This will keep these 2 circuits from receiving +12v. One is for the dome/courtesy override and the other is for the dome light.
As you can see in the above photo's i have scratched the copper tracer up a little so i can solder to it. We will be using a piece of wire (or whatever you can think of) to connect both of these tracers to the ground circuit. We will be using the ground tracer going to the light inside the switch itself as our main ground. So we need to attach the dome light tracer to the ground pin (#6) with a tiny piece of wire as shown:
And attach a longer piece of wire to the dome override circle and to the light tracer AT the light:
And it will look like this:
In case you're wondering, the bottom 3 right hand side pins will not be used. They go to the LED's that would indicate which mode you're in by turning the switch knob. Some upgraded vehicles such as fully loaded trucks, as well as escalades had the LED indicators.
Now we need to attach the parking lamp pin (#2) to the dimmer input pin (#11) with a jumper wire. As well as attach the internal light pin (#14) to the dimmer return pin (#12). This will allow the dimmer to receive power once the parking lamps and illumination lamps get switched on. And by connecting the internal lamp to the dimmer return pin, this gives the internal lamp its trigger to power on as well.
Now we are DONE internally. Everything will act as it should when using the switch as normal.
Now to move to the outside wiring. A brief explanation on the factory wiring. I have included a diagram at the top to show the pin location and wiring color for the harness you will need to buy for your updated switch. I have also included on that page a badass msPaint schematic i did of the 99-02 connector with wire funtions/color, and a quick schematic of the PAC TR-7 module you will need to buy ($20 on ebay).
In the schematic above on the left hand side you will see the factory wire color that needs to be crimped/soldered/connected however you choose, to the 14-way connector. Ill tell you this right now, if you have access to the connector crimp on pins, you can make this look like almost a factory install by crimping them onto the factory wires and plugging them into the new connector. I chose the solder/heatshrink method.
Here are a few pictures showing exactly where each one will go....it would be pointless to explain why/where when the answer is in the schematic. If you have any questions i would be happy to answer them to make it a little more clear and understanding.
Edit: This picture ^ shows the white wire with a Diode placed over it. I forgot about this completely but have gone back and soldered a 12v diode in place. I think the part number is a 1N4004. Anyways you need this diode on the white wire for the TR7 module with the stripe facing away from it. This will keep the normal pulses from your dome override button from backfeeding into the unit causing your dome light to flash twice. You can get a 2-pack of these diodes for a buck.
1N4004 Micro 1-Amp Rectifier Diode - RadioShack.com
You may be wondering what the extra wiring harness is that you see in the pictures. This harness goes onto the Pac TR-7 trigger module you need to buy. Thanks to Forklift on GMFS for pointing me towards this. This was the last thing i needed to figure out to make this project worth doing and he came thru with good info.
What the TR-7 does is actually a multitude of things. We will be using it as a double pulse output. While in 'AUTO' headlights mode, the 99-02 BCM's (body control modules) need to sense a double negative pulse from the dome override button to turn the headlights off. This is why you press the button 4 times. It will ground the circuit twice and the BCM says 'hey....turn off the headlights'.
With the new switch you have the option of turning the knob back to turn the headlights (and Daytime running lights) off on newer trucks. Much easier than pressing a button 4 times. Good thinking GM.
So we need the TR-7 to take the trigger we will give it by turning the knob backwards and convert it to a double pulse output. (You need to program this feature onto the TR-7 with the included instructions....it is very simple to do.) Whats awesome about this unit is that it is tiny and compact, which is everything i was hoping it would be because i wanted it to be complete with the headlight switch. And it was the perfect size! Here are some dimension pictures for reference as well as where i mounted it. I used double sided sticky tape to mount it to the back of the switch.
In the above picture i mounted it upside down....it needs to be flipped the other way. Oops!
Ill explain the hookup on the module:
Connect the Red wire to the small orange factory wire.
Connect the Black wire to the factory black AND black/white from the new connector.
Connect the Green wire to the dark green wire coming off the connector.
Connect the White wire to the purple factor wire AND the purple wire from the new connector.
Red receives constant or switched 12v power.
Black receives ground of course.
Green will be the trigger wire to activate the module. When you turn the knob backwards it sends 12v power to the module.
White gives out the double negative pulse to the dome override purple wire which the BCM needs to shut off/turn on the headlights.
This module is the key to the project.
I tied the other unused wires together because you never know if you may use them for something else down the road!
Now check to make sure everything is acting properly as it should and put everything back together!
Before (with updated foglight switch):
After:
And a cheesy ass video of it all working. For the record i hate hearing my voice....so if i sound like a douche i apologize!
