Hunter. fotfive'dpokinoutdaside Mar 13, 2012 459 0 0 North Carolina Nov 18, 2012 #1 What does your 4l60e's transmission temperature usually run at?
Tukn4s New member Jan 24, 2011 1,856 268 0 Nov 18, 2012 #2 Usually about 70 cooler than the engine, unless its around 100 degrees outside. Then it's closer to 50 degrees below
Gannon That Guy Jun 10, 2012 4,711 49 0 Logansport, Louisiana Nov 18, 2012 #3 Mine runs around 150 in cooler weather, and 180-190 during the summer. I need a trans cooler though.
Hunter. fotfive'dpokinoutdaside Mar 13, 2012 459 0 0 North Carolina Nov 18, 2012 #4 I'm at around 150* but it takes a long time for it to reach it.
Ginger Bubbles Jan 25, 2011 23,997 485 0 Julian's Shed @ Sunnyvale. Holy fuck boys, this sh Nov 19, 2012 #5 Gannon said: Mine runs around 150 in cooler weather, and 180-190 during the summer. I need a trans cooler though. Click to expand... same here,
Jimmy Formerly SouthernprideTX May 8, 2012 1,996 3 0 North of Houston, Texas Nov 19, 2012 #6 Fgt 4l60es over heating.
Ginger Bubbles Jan 25, 2011 23,997 485 0 Julian's Shed @ Sunnyvale. Holy fuck boys, this sh Nov 19, 2012 #7 your fine as long as your below like 210 or 220, if your over that, then its melt down.
P Peyton676 New member Mar 10, 2012 1,588 3 0 Le Boot Nov 19, 2012 #8 hottest i can get mine to run is 140 with a converter,if its cold,trans temp wont even come off 100degrees on cluster,and its accurate,ive checked it with multiple scan tools
ScottyBoy The LED Man Apr 6, 2012 1,320 21 0 Nov 19, 2012 #9 Hottest I have ever seen mine get was around 190. It usually ran about 170-180 in the summer time though, and about 150-160 in the winter.
